Hi all, I'm using a DAQmx base that is reading two channels of voltage, the first is from a battery, the second is from some other voltage source. As you can see on the picture (2.gif), the waveform chart reads them correctly and separates them, with the Battery at around 1.5 volts and the other voltage source much lower. However, the first chart (1.gif), is supposed to be stacking two plots, the top as the battery voltage and the bottom plot as the other voltage source. It appears that it is using two plots that are identical, with the top of the lines on the plot being the battery voltage and the bottom of the lines being the other voltage source's voltage, and it is filling it in with some random stuff. Can anyone help me fix this first graph so that it will display both separately? I do not know why this is not working. Thanks.
Message Edited by Doagie on 06-23-2005 03:50 PM
