One of channel is read at 5V ONLY when X>5V and Y<5V by dmm
I want to take two voltage simultaneously. One of the data record and hold at 5V when it is over 5V while other is below 5V. Other cases are normal say both are over 5V or blow 5V.
(2,701 Views)
This forum is reserved for questions about the LabVIEW DSC module. To get a faster response in future cases, you should post to the Measurement Hardware forums.
Michael Shasteen
Applications Engineering
www.ni.com/ask
1-866-ASK-MY-NI
(2,701 Views)
I've written an example that does what you want without hardware. If you run the example you will see that the waveform chart will hold at 5 only when reading1 is above 5 AND reading2 is below 5. Go ahead and change reading1 and reading2 manually while the program is running and you'll get the idea. You will need to add the VIs to read from your hardware and you will be set. I hope this helps.
Todd D.
(2,701 Views)
