One of my axos resource appears grayed out when I select it.
I am working in a small application with 2 motion axis. After configuring my hardware and start working in the code I notice that 1 of the axis resources appears grayed out when I select it from any resource constant. The motion system is not working and I thing this is the reazon. Could any one help me with this issue.
I have the following hardware configuration:
  • cRIO-9073 (Controller)
  • NI 9514 - Servo Drive Interface(2 of them, 1 for each axis)
  • NI 9426 - Sourcing Digital Inputs 32ch
  • NI 9477 - Sinking Digital Output 32ch
  • TPC-2106 - HMI
Ferdinand Martinez
FMO Automation LLC
(2,170 Views)
Hi nausfaratu,
As a first troubleshooting step you can take, is to swap the NI 9514 modules to see if you have a bad module. Also, can you please post a screenshot of the project you are working with so we can see the settings.
Thanks and have a great day.
Esmail Hamdan | Applications Engineering | National Instruments
(2,158 Views)
