One of these things (is not like the others)
Anyone else had trouble with the new U64 datatype?
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(3,556 Views)
What kind of trouble are you having?
(3,550 Views)
Lets try this again....
The VI that demonstrates the problem should be attached...
Chris_Mitchell
(3,526 Views)
hi there
same thing with LV 7.1 and SGL, DBL or EXT - precision inputs. seems to be a limitation due to the algorithm used for calculation of sin(x).
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,510 Views)
I agree, this has nothing to do with U64. It is just a bug in the sine function that returns the input number if the input is larger than a certain (very big) threshold. The value of the U64 can reach this threshold, while it exceeds the range of U32 and below.
As a workaround, you could use "quotient and remainder" and divide by 2*Pi, then feed the remainder to the sine function. In any case, it probably does not make much sense, because the sine function is a DBL function and you'll run out of meningful digits at 1e15. A periodic function such as Sine will not make much sense if the minimal increment jumps many periods. All you see is randomness.
Still, I agree that there is a bug. Sine should probably return zero and not some value outside +/-1 for huge inputs. 😮
(3,497 Views)
So in LV a circle DOES have a begining and an end Smiley Surprised
And I was so looking forward to that next Big Bang Smiley Sad
Ben
(3,482 Views)
