One or More Feeds Are Inaccessible
Hello, I'm trying to add some software using NI MAX, but I am getting this error:
"One or More Feeds Are Inaccessible" Error When Installing Software to NI Linux Target.
I tried following the One or More Feeds Are Inaccessible Error When Installing Software to NI Linux Target - NI guide using both the offline and online methods, but it's not working.
With the online method, the cRIO doesn’t have access to the internet because I can't ping anything.
(3,004 Views)
If your cRIO does not have access to the internet, you need to use the offline installation procedures. Make sure you follow the steps in Installing Software to Offline NI Linux Real-Time Targets
https://tmesystems.net/
(2,961 Views)
What ever you do… Do not sign out or delete the app like I did… You won’t be able to log back in; saying not available right now… thus have to use the browser version of it.
(2,937 Views)
Thank you for your response. I tried following the guide, but it didn’t work.
(2,918 Views)
Did you find any solution? What do you mean by using the browser version?
thank you,
(2,916 Views)
