One plane balancing
I am interest to know about one plane balancing. I have the NI 9229, LabVIEW 2010 and the Sound and vibration toolkit.
I am planning to do one plane balancing (rotor disk). Actualy my machine has an accelerometer and a inductive sensor for rotation.
 I tried to develop a VI and i used the Two-Plane Balancing Using LabVIEW PDA but it doesn´t work because it use influence coefficients
Any help as to how to tackle this or ideas on where to start would be greatly appreciated.
Thanks to all in advance for your assistance.
I tried to develop a VI and i used the Two-Plane Balancing Using LabVIEW PDA but it doesn´t work because it use influence coefficients.
(3,768 Views)
I am also interested in single plane balancing. Pl. guide.
Sam
(3,557 Views)
Have you started coding or planning your code (design)?
If so, what do you have so far?  What kind of help do you need?
(3,549 Views)
I mean I need help in getting magnitude and phase information from acclerometer and tachometer.
(3,381 Views)
