One subpalette in a foreign language
The System configuration subpalette some how changed to a different language (quite sure it was not that way on install) LV17. How do I change them back to english? all other subpalette items are fine.
I was looking to use these but I would like it in a language I can read..
I was able to find the specific msi and did a reinstall and that seems to have worked
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
(2,493 Views)
Hey Jeff,
If I'm not mistaken, the System Config API should be included in the DAQmx download. If you don't have DAQmx, you can download it online and it may fix your language issue by overwriting the existing API. If you currently have DAQmx, try force reinstalling it.
Jen P.
Applications Engineering
(2,437 Views)
