Only intilize 1 time...
Hello people,
I've a question. I have a parameter called X. I only want to set the parameter X if parameter Y(bool) is true. I always used a case structure and then I always left the TRUE case or FALSE field empty depending of what I wanted to be intialized...
Now my question to you is... ain't there a easier way?
(3,711 Views)
What is your definition of a "parameter"? An indicator maybe?
(3,709 Views)
yes it's a indicator.
(3,705 Views)
What you are doing is probably as easy as it gets. 🙂
(3,697 Views)
oh well okay Smiley Tongue
I was hoping that there was a shorter way or I say it wrong I was hoping that there was a cleaner way of solving it because it feels a bit dirty a empty case in my opinion.
(3,693 Views)
Well, LabVIEW can execute an empty case very efficiently! The ideal code! 😄
(3,687 Views)
