Only one case
Hi
I was fouling around about and tried to remove all cases, it didn’t work but I stumbled upon this.
When I started by a simple case and then removed the TRUE case the vi was executable and ran the FALSE case regardless of the input, it is not possible to run if I remove the FALSE case first.
Is this something you have experienced? Is it a weird feature, a bug, something wrong with my installation or a very important part of LabVIEW that I don’t understand?
I’m running LabVIEW 7.1 on Win XP
pp45
(2,769 Views)
Looks like your only case turned into the default case 😉
(2,766 Views)
