Only output a single value from a nested case structure
I am reading a barcode and based on which bars are present, I want to assign a value. I have set up nested case-structures to assign values for each of the possible set-ups of bars that are present. Now i am trying to figure out a way to only output the value of the one case that is true. Is there any way to do this?
(3,145 Views)
It would help your cause if you showed us your code.  But it sounds like you do not need nested case structures.  You can have a number or a string be used for the case selector and you can have a lot more than 2 cases for a single case structure.
(3,121 Views)
