Open Block Diagram After Deployment on a Non-LabVIEW PC
Hello all,
I have a application created in LabVIEW which will be deployed on a PC which does not have LabVIEW Development System installed in it, but only the RTE. With this application, I am also deploying the dependent VIs in a separate folder.
My question is, is there any way we can open the BD of these dependent VIs in Highlight Execution mode on such PC with no LabVIEW Development System installed? I just want to view the BD of the VI in highlight execution mode, I don't want to edit/make any changes to the VI. Then obviously, we would be needing the LV development system.
Since I've left block diagram (allow debugging) option enabled before deployment, I hope there must be some way we can acess the BD in highlight execution mode. I know that BD get image property works in PC with no LabVIEW Development system installed, so there must be some way or other to access the block diagram in highlight mode.
Can anyone try to help in this?
Thanks in advacne!
-FraggerFox!
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(2,539 Views)
You can't do it on a PC without the development environment.  If you have debugging enable in the .exe, you can connect to it remotely over the network from a PC with the development environment to watch the execution.  Look for "remote panel connection" under the tools menu.
(2,505 Views)
