Open LabView DLLs with Automation Open
Hi All,
I would like to understand the way I can call the LabView dlls using Automation Open from LabView. Can any one provide me a simple example which helps me understand this.
Ramana
(Using labView 8.0.1 Professional
OS: Windows xp)
(3,106 Views)
AFAIK, you can call a DLL (built in any language including LV) in LV using the Call Library Function node.
I dont think you can use the Automation Open function to call a DLL in LV, It is basically meant for calling ActiveX functions.
- Partha ( CLD until Oct 2027 🙂 )
(3,094 Views)
Also, CINs CANNOT be used to call DLLs in LV. They are meant to call C code directly in LV.
(3,072 Views)
