Open URL in Default Browser
I am using the Open URL in Default Browser.vi to transfer a string of data into a url. The browser opens over the labview window when this takes place. Since I will be writing data once a minute, I would like the window to stay minimized or not even open. Is there a way to do this?
Thanks.
Message 1 of 8
(5,068 Views)
Well somewhere the function 'open url in default browser' is called with a valid URL.
You should just remove this function from the code, In that way the browser isn't called.
Ton
My LabVIEW Ideas
Message 2 of 8
(5,046 Views)
Hi Jasonalan.
If You are using ActiveX Calls, You can just put in a Property Node, using the "Visible" property. Change it to "Write", and wire a "False"-Constant to it.
See attachment.
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 3 of 8
(5,015 Views)
thanks BCL@Servodan for this vi it was very useful. I am working in project where i have sevral URL to be executed One By One. Right now i am using internet explorer and each time i execute a URL w new window is opened. the question is how can i opened all this url the same window and if it is possible in the same tab
Cordialement
M.Safouene
Message 4 of 8
(4,533 Views)
Hi M.Safouene,
It appears that this thread is seven years old.  I would recommend creating a new thread beacuse you would have better luck getting a quality response.
John R.
John R.
Message 5 of 8
(4,510 Views)
The attached vi will work in windows.
Message 6 of 8
(4,492 Views)
hi Jordan
Can you please save it for a previous version ? i am using labview 2013 thanks
Cordially
M.Safouene
Message 7 of 8
(4,471 Views)
Message 8 of 8
(4,465 Views)
