Open VI in early version
Is it possible to open VI created with LabView 6.1 in LabView 5.1 ?
(2,804 Views)
No. To get a 5.1 version, a person with 6.1 can save it as 6.0 and then a person with 6.0 can save it as a 5.1 version. This all assumes that the 6.1 program doesn't have features unique to that version such as the event structure.
(2,804 Views)
> Thanks
Possible, but it takes a few steps. As far as I know, in LV 6.1,
you can save back to 6.0. (Use Save With Options and the "Save for
Previous"
option.) then you need to read it into 6.0 and Save for Previous again.
(Ironically, from 6.0, you'll save back to 5.0, so when you open in 5.1
it will upgrade a version.)
Dave
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
(2,804 Views)
