Open VI reference is very slow if VI is not already loaded in memory
If you open the VIs often, look into how the Actor Framework calls VIs asynchronously.  In the "Launch Actor Core.vi"  it does it in a loop because the opening of the reference take a lot of time but you can use the same reference to spawn multiple clones.  Not sure how this works with VIT rather then VI though.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
Message 11 of 12
(1,658 Views)
Thanks TheQ for recommending using Actor Framework, I will definitely consider it for new projects. It appears that the problem is gone after I do a "mass recompile". Truth be told, this project I got from someone who was running LV2013 even though he converted it to LV2015 long ago. So I suspect one of the child VI was still LV2013 and it took too long to convert it to LV2015. Thanks
Message 12 of 12
(1,636 Views)
