Open VISA Session
I attach also two images of this example, front panel and block diagram
Message 11 of 13
(1,759 Views)
Have you tried running the shipping example called 'Locking.VI'? This is where you need the duplicate session with the VISA Open.
Message 12 of 13
(1,740 Views)
is it necessary to use always VISA open block in duplicate mode? because I need to make a SubVI that access to serial device, and I want to perform vary access at same device in concurrence, using same SubVI. In this case my subVI must open a duplicate session and use VISA lock async to request an exclusive access to same device.
I try it in my example, using two VISA open blocks (in duplicate session mode) before lock async block, but I have some problems, both two segments generate same error: -1073807345 (VISA:  (Hex 0xBFFF000F) Specified type of lock cannot be obtained, or specified operation cannot be performed, because the resource is locked.)
Message 13 of 13
(1,730 Views)
