Open and close front panel
I wish to have a VI that works as a main menu from which you start new
VI's depending on your choice. When the new VI start I want the main
menu to hide it's front panel temporarily until it the second VI
returns.
Anyone has a solution to this?
/Nimrod
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,827 Views)
s_nimrod@my-deja.com wrote:
When the new VI start I want the main menu to hide it's front panel temporarily
until it the second VI returns.
If you are using LabVIEW 5.1, you can use the VI server attributes to hide
the VI by moving it off of the desktop. I will send you a sample in private
mail.
The attribute (property) you need to use is Front Panel Window -> Window
Bounds.
Set it to something that is larger than your window size, like 2000, 2000,
2200, 2200.
I hope that this helps,
Bob Young
(3,827 Views)
attached winutil.llb can be one solution.
received llb from ni germany years ago.
works well - but don't ask for more information.
does anybody know where this is published now?
maybe new stuff in LV5.1 is smarter - read mail from Robert Young.
Manfred
s_nimrod@my-deja.com schrieb:
> Hi,
> returns.
> /Nimrod
> Before you buy.
(3,827 Views)
Sure, this is published on the NI site by NI (from whence it originally came)
in the Example Programs Database:
http://digital.ni.com/explprog.nsf/websearch/ebf11dd1f0feaef3862566790072a983
--John Lum
(3,827 Views)
