Open and display XML contents
Darin, This looks perfect! I'm looking forward to tinkering with you VI and adapting it to my needs!
Thank You! -  John
Message 21 of 35
(2,121 Views)
Darin, Can you upload the VI? -  John
Message 22 of 35
(2,120 Views)
EasyXML from JKI is now free, I believe.
Message 23 of 35
(2,117 Views)
I posted a snippet, just drag it to your block diagram.  I don’t even save these example VIs, just the snippet.
If it does not work for you I will recreate the VI and post it when I get back to my computer.
Message 24 of 35
(2,109 Views)
Yes it is and also open source : https://github.com/JKISoftware/JKI-EasyXML
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 25 of 35
(2,097 Views)
Darin, The only attachment I see is the png file. I dragged and dropped the png onto the block diagram, and it turned it into a web link. Is there another file I missed somewhere?
Thanks for your assistance!  - John
Message 26 of 35
(2,088 Views)
Powell, I have installed Easy XML, thanks for the link! -  John
Message 27 of 35
(2,087 Views)
Here you go.
Message 28 of 35
(2,077 Views)
Darin,
Great! Much thanks! I will study this in detail! - John
Message 29 of 35
(2,073 Views)
Hello!
I'm trying to recreate the "Load XML with Parser API" which is an example in the "C:\Program Files\National Instruments\LabVIEW 2016\examples\File IO\XML\Parse XML" folder.
The VI I have uploaded shows the first items in the VI, a build path and a load xml file. "b.xml" is a copy of "testconfiguration.xml" which is used by the Load XML with Parser API VI.
I get  Error -2628 occurred at Invoke Node in NI_XML.lvlib:Load XML File.vi->load and parse altered test xml Saturday 5 11 19.vi
when run. All I have done is cut and past a portion of the example VI, modified how the file path and name is established, modified the file name, and truncated the remainder of the example VI I am drawing from.
Any help? -  John
Message 30 of 35
(2,061 Views)
