Open and run .hws file on USB-6363
I have a USB-6363 and I would like to have the program output the file from a .hws file so the user can make quick and easy changes to the digital output.  The array labeled 'output array 79-1' works fine connected to the 'DAQmx Write.vi' but if I use a 'ni HWS Retrieve Waveform.vi' connected to the 'DAQmx Write.vi I get the following error.
Non-buffered hardware-timed operations are not supported for this device and Channel Type.
Set the Buffer Size to greater than 0, do not configure Sample Clock timing, or set Sample Timing Type to On Demand.
Your help is greatly appreciated.
NOTE - I had to change the .hws to .txt as it wasn't a valid extension, go figure because it's made by NI.
Bill
(2,529 Views)
What is your LabVIEW version?
What is your NI DAQmx version?
(2,495 Views)
What is your LabVIEW version?        2012 f2
What is your NI DAQmx version?      NI-DAQmx Device Driver 9.6
(2,491 Views)
