Open file on click button and save
Hello.
I have a confusing problem - i am trying to save data on click button(data are changing in time). First click -> we create file(for example 1.txt), the next click we create file 2.txt ....etc
The first click is O.K, but the next one is not.
The button doesnt change the state on output => i cannot create another file...
Does anyone have an idea whats going on? Where i made a mistake?
(3,474 Views)
After you first click Zpaisz 2 button, you'll enter in the specific case of EVENT STRUCTURE... now the only way to come out of this case, you need to click stop button.
Actually I'll suggest you to build a STATE MACHINE.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,465 Views)
Thanks, i will try this solution
(3,453 Views)
Hi Mirasoul,
According to your code it looks like you do not understand fully the functionality of Event structure. I would suggest you to go through help https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/event-structure.html , mainly part "caveats and recommendations for using events". Also article https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html can help. In addition to that, try to reduce the code inside of an event structure as much as possible.
Did you try to turn on the Highlight Execution and see how the program works? Because you have to press "Zapisz 2" button first, then due to dataflow paradigm file is opened and every 100ms, random number is written. After clicking on the stop button, program will wait on another event to occur. Additionaly, you cannot stop the program using standard methods (button, timeout) and using abort button is the only way how to do that. If I can recommend you, avoid to use abort button, it can be dangerous and sometimes when you are working with files, you can lose the data easily.
You could use state machine, it is common and easy-to-implement architecture, if you want to use events, you can use "Producer/Consumer Design Pattern (Events)" via File > New and there select VI > From Template > Frameworks > Design Patterns. Basic idea of this architecture is that in the top loop, every configured event is caught and in the bottom loop, you implement the functionality. Ideal can be to create a state machine in the bottom loop and just send from top loop command (state) what should be done. So state machine will have states like "Open File", "Write File", "Close File" and you will send this states through queue.
Martin
(3,427 Views)
