Open .lvm file while program is running
How do I open a .lvm file within my program? I've tried using the Open/Create/Replace File dialog with File Dialog specifying the path and I can get to the point to select the path, and it doesn't open the file.
(3,244 Views)
Can you please post your code so we can see what you are doing.
Cory K
(3,235 Views)
Accepted by topic author kaitlin
I actually just got it to work by using a system exec.vi... thanks!
(3,232 Views)
