Open multiple instances for a VI
Dear all,
  I created an application to open multiple instances(RecipeEditor.vi as attached)works fine in debug mode. But, after I build it to an exe, it gives me error 1003.
Can you please show me some pointer what is wrong?
Please find attached zipped package
Thank you in advance.
Vincent
Message 1 of 13
(4,478 Views)
your Recipe Editor seems to be password protected!
Regards
Freelance_LV
TestAutomation Consultant
Message 2 of 13
(4,468 Views)
Yes, LV. Will that cause errorcode 1003?
Message 3 of 13
(4,459 Views)
No, error 1003 is not likely to be created by password protection.
You have to either unlock the VI and post it again or tell us the password. Otherwise, we can only guess about reasons.
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(4,456 Views)
Do you include the vi in the build ?
How do you find the vi and get a reference ? by relative or absolut path ?
Is the path correct in the exe ? remember that the path in a exe most likely is NOT the same as in the dev. environment.
Message 5 of 13
(4,447 Views)
OIC.
  Please find attached unlocked file
Message 6 of 13
(4,445 Views)
Sadly, there is still an non-empty password configured....
Norbert
Expert: Geometry
Message 7 of 13
(4,441 Views)
my apology, Norbert.
I attached the wrong file. This attachment is password removed.
Message 8 of 13
(4,434 Views)
dk,
  Thank you for your reply. I am relatively new in Labview.
I did include the vi in build
vi is by absolute path
Message 9 of 13
(4,433 Views)
What are you entering in the vi path control that you have, when you run your exe?
And just a tip, start trusting the data flow. You are using too many sequence structures, that has no meaning.
Message 10 of 13
(4,421 Views)
