Open unknown binary file structure and save to TDMS
Hi!
I am trying to recover some data acquired in my lab a few years ago using LabVIEW 8. I am able to read the ".BIN" file but I don't know the full structure of the data. I know the following:
* it has both string and numerical values.
* the beginning of the file should have, date of acquisition and scan rate
* the array is composed of at least 4 columns
* The array should have, time data and waveform data
I have the following files:
* Old .vi file -> unable to open, I assume is due to LV8 requirement which I don't have
* Old .exe file with dependency runtime LV 8 -> I was able to open them but they don't provide much information on the structure of the file
* Bin files
* partial data stored in a txt file
I was wondering if there is any recommendation on how to proceed to fully recover this dataset
Here is a screenshot of the hex file
(2,072 Views)
You can't open it because there is an issue with a dll inside of it.  At least that's what it says when I try to open it (with LV2018).  If you don't know the data structure then you are reduced to guessing.
Bill
CLD
(Mid-Level minion.)
(2,056 Views)
Thanks Bill
(1,960 Views)
