Open with... on LabVIEW files doing strange things
I have LabVIEW 2010-2012 installed. I am using Windows 7 32 bit. If I right click a VI and go to open with... it always shows 2010, and will either show 2011 or 2012 depending on which I had open last. If it shows 2010 and 2011, but I go manually open 2012 from the start menu, then when I right click a *.vi file and select open with... it shows 2010 and 2012 instead. Now, if it's showing 2010 and 2011 and I choose open with, choose default program... and select LabVIEW 2012, nothing happens. What I've had to do in this case is open 2012 then choose file-> open... and browse to the VI. Has anyone had this problem or does anyone have suggestions? I think I've had this issue the whole time 2012 has been installed, it's just now I've gotten to the point where I'm sick of dealing with it
(2,571 Views)
Personally, I like to use the LabVIEW Shell Launcher found over on LAVA.  It will open the version of LabVIEW the VI was written in.
http://lavag.org/topic/12241-labview-shell-launcher/
(2,561 Views)
Weird, I just noticed if I try and right click and say open with 2012, it tries to open in 2011 and tells me "file is newer than the current LabVIEW version"
(2,554 Views)
I'll definitely try that.
(2,553 Views)
