OpenG "Array" library v2.7 released
Hello Everyone,
There is a new version (2.7) of the OpenG "Array" library (oglib_array package) available. This library contains several routines manipulating arrays.
This release...
1) release adds the following improvements to "Filter 1D Array":
A) added poly members for scalar value of "items to filter"
B) added "filtered item indices" (pointer array) output
C) refactored code to use "Search Array" and "Delete Elements from Array"
D) improved VI description.
See here for more info.
You can download+install this package using VI Package Manager. Just press the "Check the Network for Available Packages" button to refresh your package list.
Thank you,
Message Edited by Jim Kring on 04-08-2007 12:56 PM
(3,574 Views)
Jim & fellas,
Great work !
I ve installed VIPM today & saw so many VIs will be very much useful in my project.
- Partha ( CLD until Oct 2027 🙂 )
(3,554 Views)
Partha,
That's great!  I'm happy that you found some useful stuff.  If you have any feedback or ideas for other tools, let us know.
Thanks 🙂
-Jim
(3,525 Views)
Nice work Jim! 😉
Tomi Maila
(3,520 Views)
(3,508 Views)
