OpenGL to Labview
Assuming we have a drawing created in openGL code, how can we pipe that into labview for display?
(4,550 Views)
If you know of an ActiveX control which can display OpenGL graphics, then you can probably use an ActiveX container to display it.
___________________
Try to take over the world!
(4,537 Views)
I am no expert here, but if you have LabVIEW 8.20, check out the new 3D picture control.
(4,525 Views)
errante:
Here is one more resource you can check out about the LabVIEW 3D Picture Control. I hope this helps.
Rudi N.
(4,477 Views)
Also, if you're not related to the person who started this thread (or even if you are), you can try the suggestion made there.
___________________
(4,464 Views)
