OpenSSL question
I have a text file that has been encrypted in another program using OpenSSL. I have been given the Key and IV so that I can attempt to decrypt it in LabVIEW for some testing I need to do. Is this possible? If so, what is the best way to do it?
Thanks!
(1,596 Views)
IV and key is not enough information,
If it is one of the AES modes then there exists several VIs which can encrypt/decrypt AES. There are less native LabVIEW VIs for other algorithms.
Also .NET is possible
if you need more than only decoding a single file, then the Encryption Compendium For LabVIEW might be something for you.
(1,512 Views)
