Openg Get Cluster Element Names__ogtk.vi
it seems doesn't work if cluster contain map or set
Message 1 of 13
(6,423 Views)
Check if the elements in your cluster constants have non-null labels.
Message 2 of 13
(6,414 Views)
map cann‘t be null???
Message 3 of 13
(6,408 Views)
I don't have the OpenG Toolkit, but when I use the built-in functions, it works for me.
Message 4 of 13
(6,387 Views)
thank you,but i use lots of OPENG VI,This troubles me
Message 5 of 13
(6,377 Views)
Look inside the OpenG code.  See if you can find where things are going wrong.
Message 6 of 13
(6,363 Views)
As far as I know, the OpenG VIs are older than maps and sets and therefore cannot handle maps and sets.
Message 7 of 13
(6,360 Views)
I don't know how to fix
Message 8 of 13
(6,358 Views)
This is true, but on the other hand the Label.Text property is rather basic, implemented in the Control class.
And Maps are undoubtedly controls.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 9 of 13
(6,330 Views)
This question has been asked and resolved many times already like in this post:
https://forums.ni.com/t5/LabVIEW/Get-the-name-of-each-element-in-my-cluster-in-a-1D-array-of-9/m-p/4...
Simply use the VIs present in the Data Type Parsing palette:
@ pincpanter
Not that simple, if you look at the implementation of "Get Data Name from TD__ogtk.vi", the Pascal string containing the name of the data starts at different offsets in the type descriptor, depending on the data type. The Map/Set case is clearly not implemented (at least in the last OpenG version for LV2021, which I have tested).
Raphaël.
Message 10 of 13
(6,319 Views)
