Opening Image as Separate Window
Hi All,
I would like to open some camera-generated images in separate windows in my LabVIEW code.  I could do this by creating a sub-VI that simply displays the image, and set that sub-VI to open a separate window, but I wonder if there is a simpler way to do it?  Is there a setting that would allow me to open the images separately without creating a sub-VI?
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(4,201 Views)
Use an Asynchronous Call by Reference to luanch multiple instances of your subvi passing the image to display into it.
(4,193 Views)
Depending on the OS you can use the System Exec.vi to display the images in the Windows Photo Viewer.
Ben64
(4,184 Views)
