Opening LabView 7.x vi's in earlier versions
Can we open the Vi's developed in LabView 7.x in earliler version of LabView (5.1 or 6.1), save them and use them assuming that all the libraried used are present in the earlier versions also.
Siddu
(2,623 Views)
In each version of LabVIEW you can only save to the previous version.
So in 7.1, you can save to 7.0 and so on. Of course assuming you and not using stuff that didn't exist in that version.
You can never open a vi save in a higher version.
So, to do that you must have all the in between versions installed.
I think the best thing you can do is post the vi's in this forum and someone will help you converting.
Paulo
(2,619 Views)
There are also a number of features in LabVIEW 7.x that weren't in earlier versions and won't have an equivalent in the earlier versions. Also a number of the libraries have changed.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,614 Views)
