Opening Sever Front panels programatically
Is there any way to open a VI Servers front panel without having to go throught the engine via
show details => View Severs in use.
Phil|)
(2,934 Views)
______________________________
Here's one option:
In the VI Properties of the VI Server (right-click on the Icon>>VI Properties) go to the 'Window Appearance' category. Here, select 'Custom,' then go into 'Customize.' Check the following options as needed:
Show Front Panel When Called
Show Front Panel When Loaded
This will open up the FrontPanel.. the downside is that the FrontPanel will be opened everytime the VI is called/loaded.. you won't have control over it and you have to go to VI Properties everytime to change this behavior.
Hope this helps.
Khalid 🙂
(2,934 Views)
Hi Philip,
Somewhere (could be in diagram of server) open a reference to the "Server" VI. Use a property node to set the "FPopen" property true to see the FP.
Set it false to hide it.
Keep the reference open as long as the Server is supposed to run.
Close all references when done.
Ben
(2,934 Views)
