Opening SubVIs
Does anyone know how best to open a sub VI. I want to create an options
VI that lets the user press a number of buttons, each of which executes a
sub VI and opens the appropriate sub VI panel.
Martin.
(3,266 Views)
The simplest technique is to use the VI setup
options to Open when Called, and Close if
originally closed. More flexible, but a
bit harder to use is to open VI References
to the VI and use a property node to make
its panel Visible or not.
Greg McKaskle
(3,266 Views)
