Opening TDMS files in Excel - column limit
Hi all,
I'm saving data I obtain using LabVIEW as a TDMS file and have downloaded the add-in to open the files in Excel:
http://zone.ni.com/devzone/cda/epd/p/id/2944
I'm using Excel 2007, which has a column limit of 16384 and a row limit of 1048576.  Each of my datasets is 1024 rows values large and I have 10,000 datasets in total - well within either limit.  However, the Excel importer will not open the file - pop-up errors occur and Excel opens multiple files.  Has anyone encountered this before?
Miika
(4,697 Views)
You'll probably have better luck getting an answer to any TDMS questions in the DIAdem forum...
CTA, CLA, MTFBWY
(4,675 Views)
Hi Miika,
Can you please attach a screenshot of the pop-up error and better your tdms file if possible?
Mavis
(4,656 Views)
Have the same issue.  As requested, I've attached a file with 300 dummy groups, each of which as 4 channels of dummy data.
When loaded into Excel, only the first 254 groups are shown:
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(4,443 Views)
The forum wouldn't let me post the TDMS file or a ZIP file with the TDMS file inside, so I tried posting it as a VI and that seems to have worked.  Please change the VI extension to TDMS and try loading into Excel via the importer to view the behavior.
(4,442 Views)
My issue is sheet related (limited to 254 groups), not column related.  Continued here.
(4,431 Views)
