Opening a VI from another VI.
I'm currently writing a program which shares data between 2 VI's.  I need a button on one of them which opens the other is there a way that this can be done???
Matt.
Message 1 of 12
(4,197 Views)
Hi Matt,
Have you tried to create a sub-vi? That will work, if you have 1 main VI, that will need to call some other functions that are implemented in other VIs.
Is that you case?
TN
Currently using LV 8.5
logo
Message 2 of 12
(4,193 Views)
Ok I will give that a try have you got any examples I could have a look at?
Matt
Message 3 of 12
(4,188 Views)
Hi, I don't really know what you want, but you can place SubVI into MainVI and let work them parallely. If you only want to show the Front Panel of the SubVI, than you can use the VI Server to do it. It would be the common statical call.
If you want to make something like a menue and START your SubVI dynamically, than take a look on this example:
http://labviewportal.eu/en/front-panel/83-interactive-menue
Message 4 of 12
(4,179 Views)
Have a look at what i attatched. Hope it help. 😃
TN
logo
Message 5 of 12
(4,175 Views)
Sorry but I'm using Labview 8 not 8.5 do you have those programs in an older format??
Matt.
Message 6 of 12
(4,165 Views)
Sure, here it goes.
TN
logo
Message 7 of 12
(4,161 Views)
Forgot to attatch..
TN
logo
Message 8 of 12
(4,156 Views)
Thanks for the help.
Matt.
Message 9 of 12
(4,151 Views)
Accepted by topic author gilgad2000
Did that solve your problem?
If yes, don't forget to mark the solution and to give kudos! 😛
TN
logo
Message 10 of 12
(4,146 Views)
