Opening a large text file (.cwa)
@Bob_Schor wrote:
...  There is still the "decoding" problem ...
Bob Schor
Some notes incase you do not know about the various data manipulation options that you have available.
1) An array of U8's can be converted to a string using "Byte array to string".
2) A string indicator has three display options "Normal" "slash code" and Hex.
3) The data manipulation palette has functions "Join", Swap byte, and Swap words that will let you put bytes together and swap the bytes around.
Ben
Message 11 of 15
(1,168 Views)
Thanks guys,
I've made progress (a little) as to opening the datasets and sets of data which should contain all data. I've been trying to decipher the open github code written for MatLab, but struggling with the next steps.
The .cwa files are described here (link) from where I've been reading the large files in chunks to get the header file (initial 1024b) and the first two datapacks (512b following) from where I get the data as per VI below.
Could somebody please help me to make sense of it? I believe it's going wrong where the transform of little to big endian takes place. Although I've also been playing with the promise of flattening / converting the data but I'm lost as I'm now really out of my comfort zone.
Any suggestions / mods by somebody who understands this linked to the github bits?
Sample data can be found here: (link)
Current VI:
Message 12 of 15
(1,154 Views)
Wondering if you made any progress on this? I am also trying to load a .cwa file from axivity into labview and convert to mimick a csv file.
Thank you
Message 13 of 15
(802 Views)
Can their conversion program be controlled via Command Line? If so, i'd do a System Exec and convert the file and then simply read the CSV.
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 15
(797 Views)
Hey KG16
Yep, all sorted. Bit of digging but found an old code that reads the .CWA files in straight away, but in chunks (rather than the whole file in one go)
Two bits to look out for:
a) install the <niusiaxivity_cwa_1.0.05724> driver
b) <lezen V1 - onzetting naar csv.vi> is the original on which the programme below was based
c) <Axivity Folder Analysis - Vx.vi> provides the rough structure to link it to a single and or folder analysis, whereby all Axivities were started at the same time - I've stripped it down, so you can do with it whatever you want following this.
Google Drive link - click here
Alternatively, feel free to drop me a line on pesser at brookes dot ac dot uk and I'll fire it over directly
Message 15 of 15
(759 Views)
