Opening and Closing SubVIs
You can put the subVI in a separate while loop and pass a reference of the arrays in the main to the subVI. Here's a very simple example. There are other shipping examples of control references and information on how to create them in the on-line help.
Message 11 of 13
(584 Views)
Thank you, I will look there for some additional help.
Message 12 of 13
(581 Views)
Hello all, I am using LabVIEW in a project or multiple projects and have no one in the company to ask advice on the use of the code and if I am using it correctly. I have built many executable and have learned that the methods I use work but the question is still is it correct. I have used the attached VI in the past and it works well but I was wondering is there a better way to do this. I know that you can call VIs by using the Show FP when called but for most of my application I may be a VI running a VI inparallel such as a PID loop or a process and I may want to see the Front panel and close the front panel and I use the property nodes to achieve this. My Question is simple is there an easy way of doing this or will I continue using the attached code??
Thanks In Advance
Rob
Message 13 of 13
(310 Views)
