Opening excel sheet inside Active X spreadsheet
This should be easy, but I have always had trouble with Active X opening programs.  I created the Excel_Application, called on the workbook to open, the file opens, but from there, I lost.  I would think calling on the Worksheet would be next, then find a Invoke command to extract data and display it on the front panel when I insert a activex Microsoft spreadsheet. but I was wrong.
I did search for examples and researched, but only got to where the file opens.  I need it to display in a spreadsheet on front panel so I can modify number, save the file and close.
Any help is appreciated.
TWK
(3,102 Views)
Hey TWK,
I do not believe it is possible to have an excel spreadsheet actually in your front panel, although Active X is a great way to open an excel file as you have already done.  The only way I know to make an excel sheet appear inside the front panel is using a .NET container.  The .NET container can be altered to include an excel spreadsheet.
Here is a small tutorial on using .NET
https://www.ni.com/docs/en-US/bundle/labview/page/creating-net-controls-in-a-net-container.html
Eric L.
Applications Engineering Specialist
(3,080 Views)
