Opening two submenus parallely
@Norbert_B wrote:
Do you have two mouse pointers to control these submenus? Are these controlled by a single mouse or do you use two (or more) mice?
Norbert
I have single mouse pointer
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 23
(1,151 Views)
@Ranjeet_Singh wrote:
@RavensFan wrote:
Who made the .NET application that can do this?  Can you show it with both menus being open simultaneously?
I have never seen an application behave this way.
Another question.  If you click on the first menu and it pops up, then you click on the second menu and it pops up while the first remains up (whereas normal menus the first will go away), how do you ultimately get one or both menus to go away when you are done with them?
Unfortunately my .NET application developer doesn't know LabVIEW. There are application like this also.
What I need is when user selects the second menu then I don't want first menu to be close first. If it is minimized then no problem, if it remains up but minimized fine with me.
It doesn't matter whether the .NET application developer knows LabVIEW.  I'm just wondering what their application looks like when you use it.  As I said simultaneous menus is something I've never seen and seems like it goes against any rules or recommendations about User Interface design.  Post a screen shot from this .NET application that shows this.
Show some examples if you say they exist!
My menu is like this.
Config  --> Configure the com port for communication (Obviously need to be done once)
Testing --> Testing will be done and hence pass fail and total number also will be maintained.
Report  --> That will show the report by date and model wise in one day of any model.
Add      --> Add parameter
Exit     --> Exit my application.
Now in my between testing if user wants to view the report then my numbers will again start from 0. For this I have a solution that before exit I can write to the database and retrieve it but this very lengthy procedure.
So if user is able to open testing and report vi simultaneously then the data will not be lost.
I don't understand how a menu closing causes your report numbers to revert back to zero.
If you close your application and you want it to remember data from where it left off the next time you open it, then of course you are going to have to store that info in a file.  It doesn't need to be a database.
If you are saying that going from your first menu to your second menu is causing you to lose data, then something is wrong with your LabVIEW code.  You are not maintaining the data in your code properly between loop iterations.
Message 12 of 23
(1,133 Views)
When user goes from one menu to other then I dont want for that user to close the first window then go for second. He can go for second menu then first menu VI will be minimised.
--Ranjeet
Message 13 of 23
(1,111 Views)
And you still haven't shown an application that demonstrates this behavior.
Maybe you are using the wrong terminology.  You say "menu", but perhaps you are talking about a window or some dialog box.
Message 14 of 23
(1,099 Views)
Yes you are right, I am talking about window
--Ranjeet
Message 15 of 23
(1,091 Views)
Can you post your current approach?
All we've seen up til now is a screenshot showing a menu....
Point is, as Ravens already made clear:
Browsing the menu as user normally does not trigger ANYTHING in the code. If the user CLICKS on a menu item, the code should perform some actions.
I assume now that you have one item opening an additional window. When the user again uses the same menu (primary window of the application), that sub-window should still be open even if the next menu item the user clicks on opens another window.
Is this use-case what you are talking about?
Why should anything in the menu (and its handling) deal with that "multiple window issue"?
Norbert
PS: My remark before was a joke. I have never consciously seen any OS having more than a single mouse pointer. Using several mice is possible, but they all control the same mouse pointer.
Norbert
Expert: Geometry
Message 16 of 23
(1,081 Views)
I think, we are lost in misunderstanding common terminology. Everybody except Ranjeet means with a menu a "popup menu". In my practice sometimes costumers call a window with buttons to start different actions a menu.
So Ranjeet, it is now on you to exactly and completely explain, how your approach looks like to prevent us from further guessing, what you could mean.
Greets, Dave
Message 17 of 23
(1,076 Views)
Doesn't the window stay visible if you set it to Floating?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 23
(1,073 Views)
Here is my example
After exploring I realized that I am calling each VI using call by reference. So I need to call all of them asynchronously
--Ranjeet
Message 19 of 23
(1,059 Views)
/Y
Yes window is visible but minimized after user clicks on other menu
--Ranjeet
Message 20 of 23
(1,057 Views)
