02-21-2019 11:00 AM
do any body use Openssl Library in LabView?
I'm trying to use mostly to Encrypt Text strings on AES-128-ccm.
I been looking all the forum and I can't find anything.
I Install the latest version of Openssl Library in my Windows platform.
Y developed a .dll using the Openssl in Visual Studio 2017 and looks than works in LabView, but it is unstable, some time makes the LabView Crush, the code works fine if I run into VisualStudio (with modifications for command prompt), but not for LabView (50% of time works fine)
This is my c++ code for one function:
/**************************************************************************** FUNCTION: encryptMessage(unsigned char *plaintext, int plaintext_len, unsigned char *key, unsigned char *iv, unsigned char *ciphertext) ARGUMENTS: plaintext - Message to Encrypt plaintext_len - size of Message key - Encryption key iv - initialization vector ciphertext - array where to put encrypted message RETURN: STATUS - OK if success; otherwise not OK DESCRIPTION: This method encrypts the message into plaintext *****************************************************************************/ int encryptMessage(uint8_t *plaintext, int plaintext_len, uint8_t *key, uint8_t *iv, uint8_t *ciphertext, uint8_t tag[TAG_LEN], char *comment) { EVP_CIPHER_CTX *ctx; uint8_t texttoencrypt[27]; int ciphertext_len, len; int ret; memset(texttoencrypt, 0, 27); memcpy(texttoencrypt, plaintext, plaintext_len); ctx = EVP_CIPHER_CTX_new(); // Set cipher type and mode ret = EVP_EncryptInit_ex(ctx, EVP_aes_128_ccm(), NULL, NULL, NULL); if (ret != 1) { comment = (char *) "Encrypt Message: Init AES CCM Error..."; EVP_CIPHER_CTX_free(ctx); return -1; } // Set nonce length (13) ret = EVP_CIPHER_CTX_ctrl(ctx, EVP_CTRL_CCM_SET_IVLEN, IV_LEN, NULL); if (ret != 1) { comment = (char *) "Encrypt Message: Set IV LEN Error ..."; EVP_CIPHER_CTX_free(ctx); return -2; } // Set tag length ret = EVP_CIPHER_CTX_ctrl(ctx, EVP_CTRL_CCM_SET_TAG, TAG_LEN, NULL); if (ret != 1) { comment = (char *) "Encrypt Message: TAG Error ..."; EVP_CIPHER_CTX_free(ctx); return -3; } // Initialize key and IV ret = EVP_EncryptInit_ex(ctx, NULL, NULL, key, iv); if (ret != 1) { comment = (char *) "Encrypt Message: Set KEY and NONCE Error ..."; EVP_CIPHER_CTX_free(ctx); return -4; } // set total plaintext length ret = EVP_EncryptUpdate(ctx, NULL, &len, NULL, sizeof(texttoencrypt)); if (ret != 1) { comment = (char *) "Encrypt Message: set plaintext Error ..."; EVP_CIPHER_CTX_free(ctx); return -5; } /* Encrypt plaintext: can only be called once */ ret = EVP_EncryptUpdate(ctx, ciphertext, &len, texttoencrypt, sizeof(texttoencrypt)); if (ret != 1) { comment = (char *) "Encrypt Message: Encrypt plaintext ..."; EVP_CIPHER_CTX_free(ctx); return -6; } ciphertext_len = len; // Finalize: note get no output for CCM ret = EVP_EncryptFinal_ex(ctx, ciphertext + len, &len); if (ret != 1) { comment = (char *) "Encrypt Message: Finalize Encrypt error ..."; EVP_CIPHER_CTX_free(ctx); return -7; } ciphertext_len += len; comment = (char *) "Encrypt Message: Success ..."; EVP_CIPHER_CTX_ctrl(ctx, EVP_CTRL_CCM_GET_TAG, TAG_LEN, tag); EVP_CIPHER_CTX_free(ctx); return ciphertext_len; }
Thank you for your Help
02-21-2019 11:06 AM
Maybe this would save you some trouble:
https://lvs-tools.co.uk/files/6914/4279/3239/Encryption_Compendium_for_LabVIEW-Datasheet2.pdf
