Operations Menu Problem
I'm wanting to use the "log at completion" option to save my front panel after every program execution, but for some reason on the vi I just built the option to do this is grayed out. Does anyone know how I can make this option available again?
(3,070 Views)
did you set the connector pane without relinking to the sub-vi?
Stu
(3,070 Views)
What's a connecter pane and how do I fix it if its broken?
(3,070 Views)
Hi Kura,
Is the 'Log at Completion' option greyed out for even a Blank VI? If no, then try copying and pasting the block diagram of your VI into the new VI and see if that helps.
If none of this works, then please post your VI and I'll take a look at it. Please mention the LabVIEW version that you are using.
Sincerely,
Feroz
(3,070 Views)
