Optimize table row coloring
I think there have been some threads on this, and there may not be a good solution. I'm coloring alarm rows red in a table. The image below shows how I'm trying to optimize it now. Defer panel updates doesn't help a whole lot. Is there anything else I can do, or am I pretty much stuck?
(2,951 Views)
First, deferring is certainly recommended.
Second. It helps to read the help. If you look at the help for the ActiveCell property it will point you to the very useful -1 and -2 values, which select the headers and the entire row/col, respectively. In your case you can use a [-2,-2] to reset all and then a [i, -2] for your row.
___________________
Try to take over the world!
(2,919 Views)
I definitely will use defer, I just didn't put it in this example. Thanks for the hint!
(2,891 Views)
