Option Missing from Project Explorer - Converting the Contents of a Control to a LabVIEW Class
I'm trying to convert a typedef into a class.
According to this link, titled: "Converting the Contents of a Control to a LabVIEW Class", there should be a right-click option in the Project Explorer that says "Convert Contents of Control to Class". I don't see that option when I right-click my type def.
What am I missing?
I'm running LabVIEW 2018 32-bit, Full Development System on Windows 8.
(I have a hunch that it's because I'm on the Full Development System, but I can't prove it.)
(2,785 Views)
Accepted by topic author Nicholas_Herrick
It seems likely to be the "Full" problem.  When I first started back in 2014 I was developing using the 2011 Full version and posted this thread with the same issue.
Later I switched to the 2015 professional edition and I had that option in Explorer.  I'd already converted the class manually by that point.
(2,740 Views)
