Options in Open VI Reference
I am wondering if the options can be combined in "Open VI Reference" (see attached image). I would like to select 0x20 (hide search dialogand 0x8 (reentrant execution).  I am not sure if I should be adding the two numbers and then use the sum as an input for Options? Your input is welcome. Thanks!
(3,566 Views)
Accepted by topic author AGamma
yes you can combine them just rember they are both hex so that ends up being 28 hex you could just to d a bit-wise OR of the two hex values.
Ben
(3,562 Views)
Thanks for your input, Ben.
(3,537 Views)
