Opto22 Optomux driver connection
I am having difficulties using this driver. Does anyone have any experience with it?
Firstly I am not sure how I should be connecting. The low level driver wants me to use Modem, Printer, and Other for my serial port choices (what happend to RS232?). I am not sure how the wirring should be done for this or if there are other settings I need to adjust.
I really need some help....
(2,999 Views)
Communicating to an Opto 22 device using LabVIEW is not officially supported by National Instruments. It looks like you're going to need to either acquire or create DLLs that will interface to your Opto 22 board. Then, from LabVIEW, you can call these DLLs. There are some shipping examples in LabVIEW that exemplify how to call a DLL in LabVIEW. To get to these examples, go to Help -->Find Examples and enter the keyword DLL. Furthermore, the links below should give you a good idea of how to get started in your applications.
Support for Opto 22 in LabVIEW
OPTO22 Driver on Instrument Driver Network ****please read above link first****
I hope this helps! Good luck with all of your applications!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,982 Views)
