Orbit and Timebase
I simulate an input signal and a speed profile for Orbit and Timebase VI from Sound and Vibration.
with decreasing or increasing speed the values from the signals change.
this change should be displayed continously at the orbit and timebase plot but nothing happens.
please help me
(3,654 Views)
Hey,
There should also be an example for the Orbit and Timespace with simulated data.
Where you able to run that? Does this work?
Christian
(3,625 Views)
I know this example, but in it you have only 3 settings for different speed range.
I want to change the speed with a controller.
Depending on increasing or decreasing speed the amplitude become higher or lower and that I want to see at the orbit plot in time.
erik
(3,617 Views)
Hey Erik,
Your Express VIs give warnings, unfortunately you don't display them: " VI automatically was reset because input signal should be continuous from one block to the next"
It seems that there is something wrong with your simulated data.
Christian
(3,597 Views)
