Order of Installation !
Hi to all ,
I have 2 devices that is known as Mydaq and Myrio.
And I have a license for Labview 2015 Student edition as well.
For each device there is a DVD (evalution) in my box , i think it is named as Software bundle.
Now How Can i setup correclty in order ? Like below ?
1-Labview Student Suite includes Labview 2015 , Multisim , etc.
2-Mydaq Software bundle 2016 includes Elvismx driver.
3-Daxexpress (Optinal)
4-Myrio Software bundle 2018 includes required software such as real time and toolkit.
The problem is that , Mydaq-Myrio bundles also includes Labview. And i think that  no need to setup Labview again.
Edit = For Mydaq and Myrio bundle i have downloaded 2015 version too ,  if necessary !
Thank you very much  , cheers !
(3,173 Views)
Hi to all ,
(3,127 Views)
NI will help a little, here.  If you have LabVIEW already installed, you cannot install it again (you can ask for it to be installed, but it will find it already there and just skip that step).  Similarly, if devices share drivers or other software, you can only install it once (unless it is for a later version of LabVIEW, but if you are a beginner, you want to have everything be the same version, trust me!).
When installing LabVIEW, the preferred "order" is as follows:
  1. LabVIEW.
  2. LabVIEW Real-Time Module (if that's appropriate, and for the myRIO, it might be).
  3. Other Modules and Toolkits.
  4. Device Drivers last
What I'd suggest would be:
  1. LabVIEW Student Suite 2015.
  2. myRio Software Bundle 2015.
  3. myDAQ Software Bundle 2015.
  4. Hide the DAQExpress disk (or burn it, or play Frisbee with it).
Bob Schor
(3,137 Views)
