Ordinal 2011 error going from dev. to .exe
Going from development system to .exe system I get an "Ordinal 2011 could not be found in nidaq32.dll" error. Is this related to the use of NI-VISA configure serial port? Can I use VISA in an executable?
(2,833 Views)
You definitely can use VISA in an executable, however you need NI-VISA on your target machine in order to run the program successfully. Have you made sure that NI-VISA is installed on your target? If it already is, we'll troubleshoot the problem further.
Logan S.
(2,820 Views)
LoganS Thanks for the info. I haven't have a chance to get back to look at the .exe, but I think I had the NI-VISA on the target machine. Let me ask you this, can that(NI-VISA)be part of the installer that you create at the time you create the .exe.
(2,806 Views)
Yes and no. Currently, you can't just select an option in the Application Builder to install NI-VISA as part of an application installation. However, you can include a the NI-VISA Run Time Engine (RTE) setup and other necessary files in your build, and call a batch file afterwards which runs the installation. The following KB for more information about this (it references LabVIEW 6.1, but it should still work for later versions).
How Do I Distribute National Instruments Drivers with LabVIEW Installers?
Logan S.
(2,795 Views)
