Organize listbox contents horizontally
I'm using Labview 2015 and i want to have the contents of a listbox organized horizontally rather than vertically, as you can with arrays for instance. Since, as far as i know, that isn't possible for listoboxes is there an alternative to achieve the behavior i want?
Thank you.
(3,430 Views)
You can have a multi-column listbox or an array of strings. But, can you explain what and why you are trying to display so we can offer the best suggestion?
(3,420 Views)
Hello Gregory,
The group name of a tdms file I'm reading, is a date and a comment on that day. I want to display the date as column header and the comment as the cell data below that header. (see attached picture for an example).
In multi-column listbox only the content of the first column is selectable, I want to be able to select more than one column at a time, as in in listbox i can select rows.
(3,408 Views)
That looks like a table to me.
(3,395 Views)
Thank you all for your answers and sorry if my questions seem a little bit stupid...
If I am not mistaking, a table is a 2d array of strings, it's not what i want.
I want to select a cell (or more) and the output to be the index of the selected cell (the functionality of a listbox), I don't want to edit the contents of the cell from the front panel, as in a table.
The snapshot I had attached was from a multi-column listbox and it is exactly what I need if I could select columns and not only rows.
(3,375 Views)
Yes.  A table is a 2D array of strings.
A table can be an indicator.  That means you can't edit the cells.
Do you need to select more than 1 column at a time?
Even with only 1 column to select, you'd probably have to write some background code to handle mouse events so that you program selecting columns on a table as opposed to having it more built into the indicator.
(3,357 Views)
Yes, I want to select more than one columns at a time and although a table can be an indicator of course, the cell(s) I select (even if programmatically figure out which they are)  wont be highlighted.
It doesn't seem like it is what I want, maybe I will just redesign the front panel to use the default vertical multi-column listbox.
(3,350 Views)
