Original Image does not display
Hi guys, I am wondering why the original image does not display on the front panel view. Can you please help me to identify the problem? Attached here are the snipped images of my code. Thank you.
(3,411 Views)
If you want to preserve the original image without getting changed/modifed/overwritten you should create extra IMAQ Create(User buffer).
-Original image is the reference for the image which you created and if you don't connect Img Dst for some operations the Img Dst Out overwrites the source image.
-And check the display palette for image indicator based on the image type.
uday
(3,405 Views)
Share the Actual vi/Snippet instead of Image.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,386 Views)
