Original files are missing after re-installation (Test-sequence context.ctl)
after upgrading from LV2010 to LV2013 my VIa are missing these files for eample
Labview Test-Sequence Context.ctl
TestStand GetPropertyValue (String)
I also reinstalled Teststand.
How can i get the files back? I fdont know if they were a part of Labview or Teststand-installation.
Thanks for help
TM
(3,542 Views)
Hey TM,
It soundls like the missing VIs are part of TestStand.
"TestStand GetPropertyValue (String)" is something TestStand provides, "Labview Test-Sequence Context.ctl" is also a TestStand component if I remember correctly.
It is important that LabVIEW is installed first. After, you can run the installer of TestStand. It is important that support for LabVIEW  is selected in the installer.
Regards, Stephan
(3,513 Views)
Accepted by topic author OnlyOne
Thats it.
After a repair-installation of Teststand the files are back.
(3,505 Views)
